HELP!! Somethings about Convergence criteria!! |
May 14, 2006, 11:24 |
I am runing a case about the wind passing throw some buildings. The solution does not converge. I use RKE to run my case and set the convergence criteria of the residual be 10^-3.
Due to the limit of the storage of my computer, the length of downstream is about 4 time of city size so that I can save it and export as .msh file. I have setted the exit plan be the pressure outlet boundary. In the boundary (the exit), I find that there are velocity gradient alone the boundary plan. Are the length of downstream so short that my case cannot converge? I have found from Fluent's manaul that the boundary should set a place where there are no gradient. Actually, I am not understand the meanings of this. So what does that means? Finally, Do there any other method or criteria so that we can decide the solution is converge even if the residual do not converge? Thanks very much!! |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
What value shall I set for the Convergence criteria? | steventay | CFX | 7 | May 14, 2010 12:44 |
star-ccm+ convergence criteria | star | Siemens | 2 | January 14, 2009 04:57 |
Convergence Criteria | edwin | FLUENT | 1 | February 14, 2008 19:24 |
