dynamic mesh adaption
Old   May 13, 2006, 14:53
Default dynamic mesh adaption
alessio
I have some problems in using this function since I obtain a segmetation fault using the command adapt adapt-to-gradients turb-intensity space-gradient 1 n 0.9 0.3 y 10 y so I have to use adapt adapt-to-gradients turb-intensity space-gradient 1 n 0.9 0.3 y 10 n it works but if I add other variables with the same command and at set the same gap of iterations fluent displays only that he is refining in respect of one variable.. it is only an output problem or something wrong is happening inside?
Another question: which are the suggested values? I heard abt gradient of 1e-6 but is a normalized value I hope.. bcos I have scaled gradients of ca.60 and I do a refinement every 10 steps and the iteration converges..
Last: which are important adaption function? I have a flux around a bluff body and I set the gradient of the pressure and I dont know what else it's worth..
Thank you I'm a newbie...
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Dynamic mesh in Fluent to study tire in contact with road surface lihuang FLUENT 10 March 8, 2011 10:21
Some questions about mesh updating in dynamic mesh technique lzgwhy Main CFD Forum 0 June 14, 2009 08:01
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 15:40
