prob. with unsteady RANS using Finite Rate Chem
Old   May 4, 2006, 04:35
Default prob. with unsteady RANS using Finite Rate Chem
James
Hi All,
I am having some problems with unsteady RANS using the finite rate chemistry combustion model. I am using the segregated solver and for steady RANS, i got a convergent solution. However, upon switching to unsteady RANS, i realised the temperature is increasing.
One suggestion i have seen from a past post is to use a time step that is close to the chemical time scale. How can i determine the chemical time scale?
I tried switching to the couple solver but that too is not helping. Using the implicit option, i get the message that i do not have enough disk space. Using the explicit option works but my residuals become very large and they do not seem to be dropping quickly enough.
Any suggestion(s) on how to remedy this problem will be greatly appreciated.
James
Old   May 4, 2006, 09:11
Default Re: prob. with unsteady RANS using Finite Rate Che
Kamarul Arifin
estimation of chemical time scale = Length scale / velocity scale
Old   May 4, 2006, 11:42
James Willie
Thanks for the response. Which length scale are you referring to? Is it the integral length scale? Also which velocity scale?
Counting on your assistance.
James
Old   May 5, 2006, 04:41
Kamarul Arifin
Length scale = smallest edge of mesh velocity scale = freestream velocity
Please noted that this is just a estimation of the chemical time scale.
reference : Tennekes text book
Hope this helps.
Old   May 16, 2006, 06:29
Default text book
James
Thanks so much for the hint.Can you give me the full title of the Tennekes book. I have this title with me but i am not sure whether it is the right one...Tennekes H and Lumley, J. L.' A first course in Turbulence' MIT press, Cambridge Massachusetts, 1972.
Please let me know if the title is the right one.
James
Finite Rate Chemistry Setup for Hypersonic Flow AdeeMij FLUENT 22 July 11, 2017 10:28
Difference between URANS and unsteady RANS LD696 Main CFD Forum 0 November 3, 2010 11:13
Finite Rate Kinetics Arun FLUENT 1 August 17, 2004 13:11
Combustion-Laminar finite rate model Shankar FLUENT 0 January 15, 2004 22:51
Unsteady RANS - contradiction?? Fred Uckfield Main CFD Forum 3 February 25, 2002 15:52
