May 20, 2006, 15:38 |
How to run a parallel simulation?
Hi Fluent user, Is anybody know how to run a parallel simulation on single workstation with dual Xeon processor (both processor are dual core). I know how to assign the parralel simulation on cluster pc in which I can assign each partition to each cluster but not in single workstation. I just have no idea to assign my partition to each processor. Thanks in advance.
May 20, 2006, 17:32 |
Re: How to run a parallel simulation?
It is not possible, a dual core is like 1 processor for fluent code
May 20, 2006, 21:30 |
You are misinformed. Dual core Xeons can give increased performance when you run fluent with the following switches:
fluent 2ddp -t2 -psmpi |
May 20, 2006, 21:31 |
If both CPUs are dual core, use the fluent -t4 -psmpi switch.
May 21, 2006, 04:57 |
Thanks all for reply. I have 2 processors in my CPU and both are dual core Xeon. I'm dealing with 3D simulation so can I use fluent-t4-psmpi switch? If so do you have any idea how to run such simulation? Thanks in advance
May 21, 2006, 07:02 |
fluent 3ddp -t4 -psmpi
should do it. |
May 21, 2006, 13:14 |
Hi Mac, I try to run 3ddp -t4 -psmpi but I only get the message 'cannot read directory'. Anyway I'm working on Windows XP pro machine. Do you have any idea how can I run a parallel fluent solver in windows.
May 21, 2006, 13:42 |
Just try "C:\Fluent.Inc\ntbin\ntx86\fluent.exe 3d -t4". It should work !
May 21, 2006, 13:57 |
Thanks for your suggestion anyway I just couldn't run it at all. Is it possible that my Fluent installation incomplete or didnt include the parallel fluent? If so then I will ask our primary license holder about it. Regards,
May 24, 2006, 05:47 |
I've a workstation with two intel Xeon Processors (with hyperthreading(two phisical processors but four processors appear in windows, there are two virtual ones). To run parallel fluent, i had to disable the hyperthreading, on the server board and then execute cmd and in the dos window run fluent 3d -t2. So if you have two core duo processors, i think you must try to run fluent 3d -t2.
SnappyHexMesh OF-1.6-ext crashes on a parallel run | norman1981 | OpenFOAM Bugs | 5 | December 7, 2011 12:48 |
How to run airFoil2D exapmle in parallel on 4 cores? | klausb | OpenFOAM | 2 | January 9, 2011 02:45 |
Run in parallel a 2mesh case | cosimobianchini | OpenFOAM Running, Solving & CFD | 2 | January 11, 2007 06:33 |
Serial run OK parallel one fails | r2d2 | OpenFOAM Running, Solving & CFD | 2 | November 16, 2005 12:44 |
Procedure to run unsteady simulation? | STN | Main CFD Forum | 2 | February 16, 2002 04:37 |
