Pb in conv. k-e 3D Help
Old   October 30, 2009, 05:27
Thumbs up Pb in conv. k-e 3D Help
Mines
fluser is on a distinguished road
I am running a 3d simulation using the standard K-E model.
after 10 iterations "sliding mesh simulation" (in steady state flow) values of k & epsilon are diverging. I have the message: "Turbulent viscosity limited to viscosity ratio of 1e5 in cells".
I used pressure based solver.
Can anyone help with this please? Thanks.
fluser is offline   Reply With Quote
Old   October 30, 2009, 05:28
Default mesh
CFD_4's Avatar
wayusen
CFD_4 is on a distinguished road
pl. check mesh quality.
CFD_4 is offline   Reply With Quote
Old   October 30, 2009, 05:44
Mines
I do grid--check, everything is good!
Old   October 30, 2009, 06:18
Mines
and if I make simulation in laminar flow, solution converge!
Old   October 30, 2009, 15:51
tez
Tez
tez is on a distinguished road
Try with very small under-relaxation numbers and gradually increase them to default values. That might help.
tez is offline   Reply With Quote
Old   November 2, 2009, 06:16
Mines
Hi Tez,
I divided UR factors by 100, results are better . but there are fluctuations of the epsilon parameter. After 100 iterations the residuals of k and e parameters are about 5.e-2.
tell me plz. how to increase gradually these parameters? by stopping and restart calculation and increasing URP without initializing?
Old   November 3, 2009, 06:42
Default hello
reza
greeneye is on a distinguished road
I think it is better to give a inviscid solution and then set it as a intial condition for turbulent solution.another way is to set the "turbulent insity" and "turbulent viscousity ratio" to 1 at velocity inlet.
greeneye is offline   Reply With Quote
Old   November 4, 2009, 05:26
Mines
Hi greeneye,
I apply your second proposition but k & epsilon residuals remind at too high values (about 1.e-1).
I have a simple question for you: how to use a solution as an initial condition in Fluent?
by iterating without initilize solution?
thanks
3d simulations, k-epsilon model, sliding mesh
Problems with the RSM in simpleFoam sberg OpenFOAM Running, Solving & CFD 10 February 25, 2014 19:39
[Commercial meshers] Converting Gambit Neutral Meshes plmauk OpenFOAM Meshing & Mesh Conversion 2 July 20, 2007 07:08
FvVectorMatrixresidual before solving cosimobianchini OpenFOAM Running, Solving & CFD 0 January 28, 2007 11:02
[Gmsh] Gmsh with physicals Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 9 February 2, 2006 14:36
conv variable in cfx4.4 Tad CFX 1 March 12, 2005 11:42
