modelling slug flow with pressure inlet
Prev Previous Post   Next Post Next
Old   May 29, 2006, 06:45
Default modelling slug flow with pressure inlet
Azman
I am modelling the flow of a Taylor bubble in a circular cylinder using VOF. The bubble is made up of air only, and it flows in a water as continous phase.
I know messages on slug flow modelling have been posted here before. However, most of the post suggested the use of velocity inlet to model the gas sparger. I have tried using vel inlet with a volume fraction of air = 1 and vol fract. of water = 0 in the vel inlet. After initialisation, I patched the whole cylinder with a volume fraction of water = 1, leaving a portion at the top of the cylinder with a patch of air, so that the bubble will rise up.
While the parameters above gave me a nice bubble flow, using pressure inlet instead of velocity inlet will cause the air bubble to break up axially into two, immediately after it comes out of the inlet. Can anybody explain to me WHY?
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
total pressure boundary problem ==> flow from outlet to inlet!! mrshb4 OpenFOAM 0 November 20, 2010 12:41
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 19:23
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
