May 30, 2006, 16:07 |
Volume Fraction vs Velocity????
Hello, I've been working with a model of a tank in which water is coming in from the top and getting out trough a pipe.
When I plot the contourn of volume fraction of water, it shows me that the pipe is partially full because the vf of water is zero at about 30% of the pipe's diameter. However, when I plot the contourn of velocity magnitude, it shows me that the pipe is full becouse I have velocity values around the whole diameter. If the volume fraction is zero at any point, how the velocity of that fluid can be more then zero? Please, tell me any comment or suggestion about it. I will appreciate your help. As information: - Inlet BC: Vel.Inlet - Outlet BC:Pressure Outlet - Top of the tank BC: Pressure Outlet Thanks a lot Humberto |
May 30, 2006, 16:19 |
Re: Volume Fraction vs Velocity????
mr humberto ,tell me yes if you work with a simulation of tundish chankhar
May 30, 2006, 16:30 |
No, I'm not working on it.
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Difference between Volume Fraction and Mass Fraction in CEL | foo7 | CFX | 0 | September 21, 2011 08:45 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 10:46 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
the Eulerian model and the lower volume fraction | hx li | FLUENT | 2 | October 27, 2005 06:17 |
