February 28, 2020, 02:11 |
Computer Specs
Michael Fily
Rep Power: 7 |
Please help me to build a computer with maximum budget at 5000usd for ansys fluent. Thank you
February 28, 2020, 03:41 |
Important Aspects
I am doubtful you will be able to do much with that. But here is what you should be looking for.
1. A processor with at least 2.6 GHz and minimum 4 cores. Keep the cores lesser if you do not have HPC license. Furthermore, ensure that Hyper-Threading is disabled. 2. RAM with highest possible speed, minimum 2166 MHz. With 8 GB RAM, you can load a case that has 8 million cells but you can run a case only up to 1 million cells. That also depends upon the models. With DPM or Multiphase, 8 GB RAM can only handle less than 0.5 million cells 3. Graphics cards are expensive, so, don't even try to look for GPU. That would be useless. A normal, on-board graphics card is usually sufficient. 4. HDD as per your requirement, minimum 256 GB. If SSD doesn't cost a lot, go for it in place of standard HDD. Else HDD with minimum 7200 rpm. 6. If you know Linux, use that. Prefer a little older OS instead of latest one. System will be more stable.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Two computer cluster - problems with settings | dradenkovic | OpenFOAM Running, Solving & CFD | 9 | November 13, 2017 04:16 |
Some advices to buy a computer | migmolper | Hardware | 8 | July 11, 2016 15:52 |
Using Remote Solve Manager for Single Computer | u2berggeist | ANSYS | 1 | May 21, 2016 21:01 |
Computer requirements for CFD ? | AxelPedeux | Hardware | 1 | December 11, 2015 12:32 |
[OpenFOAM] Error with using of pvbatch on Super Computer | shipman | ParaView | 5 | November 18, 2015 04:56 |
