How to set solution limit for UDS?
Like Tree1Likes
  • 1 Post By vinerm
Old   June 1, 2006, 22:01
Default How to set solution limit for UDS?
Lobby
Hi I'm solving a case but the UDS concentration always becomes negative. How can I set solution limit (min. 0) for it? thx.
Old   June 2, 2006, 20:05
Default Re: How to set solution limit for UDS?
Lobby
Can anyone here help me?
Old   January 23, 2020, 07:49
c_023 is on a distinguished road
Reviving this thread because I am wondering about that, too.
Is there a way of Setting solution Limits to a UDS equation? Maybe through a TUI command (using Fluent 19.3). I am sure that is a common problem and there exists an easy solution..
Thanks in advance.
c_023 is offline   Reply With Quote
Old   February 28, 2020, 04:09
Nobody ever came across this Problem?
Old   February 28, 2020, 05:48
Default Source
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Actually, it is fairly easy to implement. The way is already given in solidification-melting model; the source term.
Define a source for the UDS based on upper and lower limits that you want. Check if the value is beyond the limits and then multiply the difference between actual value and the bound by a large number, that's what constant in S-M model does, and apply it as a source.
c_023 likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 19:51
Ibm java gcc rrr OpenFOAM Installation 2 December 30, 2005 04:18
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
