June 2, 2006, 11:19 |
Sliding mesh error
I am modelling a 3D rotor-stator case. When I use the MRF model, it is ok. But as soon as I change it to sliding mesh, there are some warning, "Warning: Attempted to correct face handedness of 11778 faces out of total 14242 faces on zone 96". Then the grid check fails. Does anyone have any suggestions? Thanks.
June 7, 2006, 04:34 |
Re: Sliding mesh error
Did you define your sliding-mesh interface correctly (two identical disconnected faces, surfaces of revolution only, not necessarily with matching grids, one in the rotating part fluid zone, the other in the stationary part fluid zone of the flow domain)?
Razvan |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
