How to adjust wall temperature
Old   September 4, 2011, 05:37
Default How to adjust wall temperature
Pisit Chaiwiboonpol
nutow is on a distinguished road
Dear all
My problem is how to adjust the temperature of wall surface due to the heat flux which transfers from gaseous phase through the wall in each time step. If the wall is solid such cement, brick etc., heat that transfer through the wall can increase wall surface temperature.
I also know that fluent calculates heat flux through the wall by using this equation
q = hf(Tw - Tf) + qrad
but fluent just handle the problem in case of constant temp, constant heat flux as I input in the boundary condition.
So my problem is how to adjust solid wall temperature due to heat transfer at each time step.
I need your help so much.
Best Regard
Thanks for your advance.
nutow is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
udf variable for wall temperature Kiran FLUENT 0 July 31, 2008 08:31
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
About fix wall temperature in wall boundary joon Siemens 2 March 10, 2003 01:41
