June 7, 2006, 18:41 |
Cavitation Model
For a cavitating flow where mainly vaporization takes place, how can we incorporate the temperature change of mixture? My application involves high pressure drop between inlet and outlet. I understand that using ideal gas for vapor phase solves the energy equation. But it doesn't take into account the heat consumed for vaporization. In my application the process is adiabatic so the temperature change in mixture is mainly due to latent heat of vaporization. Can I have your help how can I incorporate this effect? Thank you so much for your time and help. Umesh |
June 8, 2006, 16:44 |
Re: Cavitation Model
You also need to take in account increase in temperature due to bubble collapse (compression)
June 9, 2006, 01:28 |
Hi!
I think the problem could be solved by considering both phases to be compressible. In bubbly flow you get very low sonic speeds which results in extreemly compressible flow. For example the sonic speed in vapour is approx. 200 m/s, in pure water 1400m/s and in mixture (50-50) about 15m/s. In fluent 6.2. they say it is possible to include this but as soon as one sets both phases to compressible an errof message pops out - only one compressible phase allowed. I think that the integral increase of temperature due to bubble collapse is relatvelly small if at all measureble. I hope i helpet a bit, although I didn't answer your question directly. I think some guys from Pisa University wrote a paper on a similar metter - send me an email if your interested (i think i have it), or go to cav2003 webpage - i think i found it there. By mateus |
cavitation model pressure distribution | Rahmat Arazgaldy | FLUENT | 1 | May 16, 2012 15:48 |
Cavitation model with non-isothermal flow | pitisrisuk | CFX | 0 | July 14, 2009 14:30 |
Cavitation Model | Umesh Shah | FLUENT | 0 | June 26, 2006 17:09 |
About Cavitation Model and General setting | wayland | Siemens | 0 | January 15, 2006 21:30 |
Mixture Model (cavitation) | Victor | FLUENT | 3 | April 5, 2005 04:38 |
