reverseflow at pressure outlet boundary
Old   June 16, 2006, 01:51
Default reverseflow at pressure outlet boundary
Madhukar Rapaka
hi
i am simulating a flow in a cylindrical geometry. i have defined the outflow with a pressure outlet boundary. During the simulation in fluent, i am getting a warning, that reverse flow in 23 faces at pressure outlet. I have checked my mesh, and itseems to ba ok(i mean to say that the skew sizes and skew angles, edge ratios of the mesh faces are good...some faces have skew size about 0.91). the residuals are decreasing uniformly. my question here is: will there be any problem in the final results becos of the reverse flow at the outlet.
thanks in advance
Old   June 18, 2006, 07:01
Default Re: reverseflow at pressure outlet boundary
Fabrice
No worries about reverse flow at your outlet, just try to enlarge your domain of study to decrease this phenomenon.
Fabrice.
Old   June 19, 2006, 03:40
Madhukar Rapaka
hi Fabrice
firast of alla thanks for the response. i have enlarged the domain as u said and running the fluent simulation with the new geometry. now i am getting a new message:
Turbulent viscosity is limited to viscosity ratio of XXXXXX in XX(say 79) cells. And this number is decreasing as the iterations are going forward. what would be the problem.
thanks in advance
Old   June 19, 2006, 21:13
Fabrice
I have never had this error message. I think you should read the Fluent manual about the different models of viscosity....
Cheers,
Fabrice.
Old   June 29, 2006, 08:05
kumar
what type of simulation work are u doing with cylindrical geometry? reverseflow is due to inappropriate outlet boundary conditions.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Help ASAP! pressure inlet & outlet engahmed FLUENT 0 June 13, 2010 15:33
Setting Pressure on an Outlet Boundary Richard Pemberton CFX 2 April 12, 2001 06:35
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
