axisymmetric annulus modelling
Old   June 27, 2006, 14:38
Default axisymmetric annulus modelling
shashikant
hi, I am comfused how to model annulus flow, using axis symmetry, i am not able to decide which is the correct way to model
I am modeling in gambit
pls help
shashikant
Old   June 27, 2006, 17:11
Default Re: axisymmetric annulus modelling
Jason
Model a cross section of your annular geometry in the X-Y plane, where the axis of rotation of your annular geometry occurs at y=0 (the X-Axis).
Hope this helps, Jason
Old   June 27, 2006, 17:32
shashikant
the c/s is a rectangular of say 5mm X 1000mm size and IF my inner dia is 10 mm this rectangle will be at 5 mm distance from x axis, NOW there is no edge at Y=0 to be called as axis
so i creadt a real edge at y=0, and label it axis now if I expoet the mesh i get the following error
WARN: Boundary Entity axis.8 does not contain valid entity an is not written
IS THIS method of modelling CORRECT
shashikant
Old   June 28, 2006, 07:53
Jason
No. You don't need to create an edge to represent an axis in annular flows. Fluent already knows the X-Axis is your axis of rotation.
The Axis boundary condition is only used when the axis of rotation is in the fluid volume (i.e. the centerline of a pipe). Otherwise Fluent would treat the BC as a wall, which isn't realistic... you don't typically have an infinitely thin wire running down the centerline of a pipe. That's the only reason to use an Axis BC.
For your geometry, just model the 5mmX1000mm rectangle that's 5mm from the X axis... that's it. When you run Fluent, make sure to change the solver to Axisymmetric. That's all there is to it.
Hope this helps, and good luck Jason
2d 1/2 axisymmetric annulus for POLYFLOW j0hn04 ANSYS Meshing & Geometry 2 March 7, 2020 12:55
Axisymmetric Modelling using 2D extrusion Steve CFX 0 November 12, 2008 12:05
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
Unsteady modelling technique? Carlos FLUENT 0 September 26, 2008 11:37
2-D Compressible Axisymmetric modelling jehazneb FLUENT 0 December 20, 2004 05:12
