Shock-tube test in Fluent
Old   July 5, 2006, 15:35
Default Shock-tube test in Fluent
queram
Guys, I'm beginning with Fluetn and am trying to model a shock tube test in it. Can you suggest a tutorial or example or description how to do this? There's no unsteady case in any of the tutorials I have and could not find anything on the web similar to shock tube. I only managed to initialize the domain "correctly" (I mean the displayed contours of pressure, velocity and temperature look ok after initialization). Whatever combination of BC, time step, number of steps, iterations, mesh size etc I try I still get the same pressure contours after iteration. Further, the calculated velocities are huge (always in the range of 0 to 352m/s), though initial velocities are zero and convergence is reached after around 100 iterations.
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
shock tube mecamor FLUENT 0 September 22, 2011 12:50
Stability test using fluent possible or ???? Novice FLUENT 0 July 25, 2008 05:59
Shock Tube Test queram CFX 0 July 8, 2006 04:23
Shock Reflections in Fluent Richard FLUENT 2 September 2, 2004 09:55
