July 6, 2006, 00:56 |
three phase
i am doing simulation on three phase,namely air,water and steel beads.i am getting problem in defining the materials in fluent.i define air and water as fluid phase and steel as solid phase.but when i open the panel for phases it shows only ais and water. plz help in this regard.
July 6, 2006, 07:26 |
Re: three phase
With define/phases you can just define the fluid phases. the solid phase is to define in the boundary conditions panel.
July 10, 2006, 04:54 |
Re: three phase
If you want to model the beads as granular phase, you have to define the steal as a fluid too. Under define phases, there is a option for granular media. You can find more about it in the fluent-ug chapter 18 (use of multiphase-models) and further on.
How to access only one phase in multiphase model by UDF | wersoe | Fluent UDF and Scheme Programming | 1 | January 4, 2017 07:11 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
VOF for single phase? | vuccj7 | FLUENT | 0 | April 20, 2011 19:59 |
two Phase column simulation | chemeng | OpenFOAM | 3 | August 18, 2010 12:53 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
