How to monitor pressure of points on moving wall?
Old   July 8, 2006, 07:56
Default How to monitor pressure of points on moving wall?
whpsoft
I want to get the pressure of points on dynamic mesh wall, how to set fluent to monitor these value? Thanks in advance!
Old   July 11, 2006, 02:47
Default Re: How to monitor pressure of points on moving wa
Abdula Brinza
If you mean dynamical mesh problem with actual geometry motion, I think you can create in GAMBIT small surface on the wall and create monitor for it - this surface will be attached to the mesh and will move together with it. If you need more points, you can also try to get and save values manualy using UDF.
Old   July 11, 2006, 23:20
whpsoft
dear Abdula Brinza
could you give me more details about saving values using UDF? In addition, it will be difficult to creat small surface in gambit, because it will cause mesh generation. could you give me more information?
any informations are appreciated!
regards!
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
modelise the motion of the fluid by a moving wall samnetmoon FLUENT 1 April 21, 2008 07:06
moving wall and fluid soody FLUENT 3 September 20, 2004 01:37
How to use UDF to define a moving wall lingo FLUENT 2 April 23, 2004 02:38
Values of k & epsilon in the moving wall ghlee Main CFD Forum 1 August 16, 1999 12:42
