July 12, 2006, 11:43 |
Transient Simulation questions
Hello all,
I am running unsteady calculations and I have run into a few problems I was hoping someone here might be able to answer. I have computed a solution and after some time I would like to reset the flow time value to zero. Is this possible, how do I do it? Also, after computing a solution, is there any way of changing any one scalar field in the solution only? Reinitializing resets all the scalar fields. I would like to change only the velocity field while leaving all other parameters untouched. thanks, Binoy |
July 12, 2006, 13:49 |
Re: Transient Simulation questions
To answer your second question, you could use solve>initialize>patch to just reset one variable. You might be able to reset the time using the same. I havent tried.
July 13, 2006, 06:59 |
you can do that in fluent. change the scalar which you want to change and command it to iterate.Do not initialize.
July 13, 2006, 09:35 |
Thanks for your responses. Farhath, I assume that you are also talking about the patch option when you say "change the scalar which you want to change and command it to iterate"?
the problem of my transient simulation "Floating point exception: Overflow " | alloveyou | CFX | 15 | November 22, 2012 11:14 |
about transient radiations simulation | waradevivek | FLUENT | 0 | October 17, 2011 10:16 |
Beginning a Transient Simulation | Norflow | CFX | 2 | October 7, 2011 00:38 |
Resume Transient simulation | HMR | CFX | 1 | June 28, 2011 21:13 |
Synthetic (pulsatile) jet transient simulation | aero | CFX | 0 | November 6, 2009 01:10 |
