Dependence Inlet conditions : k and eps
Old   July 19, 2006, 08:52
Default Dependence Inlet conditions : k and eps
PK
I had a look about all related post but didn't find a proper answer. I am trying to simulate the flow around some simple bluff body , like cylinder a sphere in 3D. I am using the keps realizable, steady, y+<3, fluid water. first oder in pressure , second order in M, SIMPLE.
Inlet Turbulence Specification Method : K and epsilon according to 6.2.2 in the fluent user guide.
I am using the 2 formulas to get k and eps (6.2.4 and 6.2.5 in the guide): k=1,5 x (Uavg x I)^2 AND eps = f(Cu,k,l).
1-if I used I=0,1 and l=0,8m I get some value of k and eps and get approx the right value for the Drag (Re=25000).
2-If I used I=0,01 (smaller) my drag in than 20% less.
I have used finner grid and it seems to be the same result. Does the converged solution should be independent of the intial values ? which value of I and so k should be choosen ?.
Thanks for your help
PK
turbulent jet flow RANS validation heavy_user OpenFOAM Running, Solving & CFD 12 December 17, 2015 20:35
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 04:10
Initial guess of k and eps at the Inlet. PK FLUENT 0 March 23, 2006 10:13
Boundary conditions for KEPS Tom Main CFD Forum 0 August 21, 2003 06:03
re-number dependence of diffusor-flow peter schaffarczyk FLUENT 0 February 4, 2001 02:28
