July 7, 2011, 07:25 |
user defined new material
Jatinder Kumar
Rep Power: 14 |
May somebody tell me how to define new user materials in Fluent material panel
July 7, 2011, 09:37 |
Adding materials to FLUENT panel
#2 | |
Josy
Rep Power: 17 |
1) Go to C:/Fluent.Inc (or where ever your Fluent files are installed) 2) Search for *.scm in that folder 3) You will get two folders like this: propdb.scm and thermodb.scm 4) Open the propdb.scm with wordpad 5) Copy any one of the material from list, like the one mentioned below: (turpentine fluid (chemical-formula . c10h16) (density (constant . 855)) (specific-heat (constant . 1800)) (thermal-conductivity (constant . 0.128)) (viscosity (constant . 0.001487)) (molecular-weight (constant . 136.1364)) ) 6) Paste this just before the last parentheses i.e. after the 'particle-mixture-template' parentheses. 7) After pasting, you can change the numbers as desired and while naming the material, name them as new-xyz (where xyz is the name of your material). 8) Make sure that the parentheses are positioned properly. 9) Save the file and close it. 10) Restart the system. 11) Open Fluent, load the case & data file, then go to the Materials panel. In the list, check for new-xyz This should give you the new material that you have added |
July 9, 2011, 00:39 |
Jatinder Kumar
Rep Power: 14 |
Thanks Josy !
It is working |
July 9, 2011, 02:53 |
Jatinder Kumar
Rep Power: 14 |
Hi !
I have wriiten a code for water-nacl mixture and did the same as suggested by Josy. It appeared in Fluent database tab under mixtures material type. But I failed to copy it to case file i.e. to main material panel. It shows the following error Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: #f The code written was (WaterNaCl mixture (Chemical formula . #f) (density (constant . 997)) (viscosity (constant . 8.9e-4)) ) Kindly help to fix the problem |
July 9, 2011, 04:59 |
#6 | |
Josy
Rep Power: 17 |
Quick observations on what you had written:-
a) Change 'Chemical' to 'chemical-formula' b) Change '8.9e-4' to '8.9e-04' These are trivial changes but they make a difference. Try this and let me know. Quote:
July 10, 2011, 02:32 |
Jatinder Kumar
Rep Power: 14 |
your suggestions are nice.
But still my problem is not solved. Kindly suggest something |
July 11, 2011, 01:49 |
Send the propdb file
Josy
Rep Power: 17 |
Please send the propdb file in which you have written the new material properties. I will try to read it in my system and see. Additionally, have you activated the Mixture model? |
July 11, 2011, 10:34 |
here is propdb file attached
#9 |
Jatinder Kumar
Rep Power: 14 |
July 11, 2011, 10:43 |
Where is the propdb file?
#10 |
Josy
Rep Power: 17 |
March 4, 2013, 04:14 |
#11 |
hamid
Rep Power: 15 |
what do you mean by this: Paste this just before the last parentheses thanks |
March 5, 2013, 00:07 |
#12 |
Josy
Rep Power: 17 |
April 2, 2013, 02:21 |
#13 |
Rep Power: 16 |
Dear Josyula,
i would like to define a temperature dependent material property that follows the equation: y = -1.09ln(T) + 5.740, where T is temperature in Celsius. how do i define this please?
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
April 2, 2013, 09:24 |
"define new materials with temperature dependent properties" for transient
#14 |
Moha
hi,
how to define a new materials with temperature pendent properties into FLUENT ? I need to define a materials with different temperature- enthalpy values... regards, |
April 3, 2013, 01:02 |
#15 |
Josy
Rep Power: 17 |
Mactech001 and ahvz,
It is advisable to use 'DEFINE_PROPERTY' Macro for your respective problems and hook to the material which has the temperature dependent property in the 'Define-Materials'. FLUENT Manual has an example for this Macro. Please check. Regards, Josyula |
April 3, 2013, 05:13 |
#16 |
Moha
thank you for reply, how can I be sure that, if the UDF is true and working well or not? I bring the UDF file in the below regards, start the UDF: /************************************************** ********************* udfexample.c UDF for specifying transient temperature profile boundary condition ************************************************** **********************/ #include "udf.h" DEFINE_PROFILE(Temp_Profile, thread, position) { face_t f; real x[ND_ND]; /* this will hold the position vector */ real y; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[0]; F_PROFILE(f, thread, position) = (-1e-26*x*x*x*x*x*x)+(3e-21*x*x*x*x*x)-(3e-16*x*x*x*x)+(1e-11*x*x*x)-(2e-7*x*x)+((1/1000)*x)+13; /*this formula achieved from "curve fitting" */ } end_f_loop(f,t) } |
April 3, 2013, 13:33 |
#17 |
Josy
Rep Power: 17 |
ahvz,
Can you please repeat your question again? What is it that you would like to do? The UDF which you have posted here is a DEFINE_PROFILE UDF where it is essentially applied to a boundary condition like inlet, walls, etc. of your geometry. Also, I suggest a small correction:- The equation in the F_PROFILE should have 'y' and not 'x' because you have defined y = x[0] which is essentially 'x'. If you can let me know your exact question, I try to help you. Good day. |
April 3, 2013, 13:58 |
#18 |
Moha
Dear Josyula,
thank you for reply, I am trying to do transient analysis for my model. I used "curve fitting" method to achieve the temperature -time equation which is presented at below text. you right. this is the temperature profile as a convective heat transfer through the model which I want to impose to the wall geometries. /************************************************** ********************* udfexample.c UDF for specifying transient temperature profile boundary condition ************************************************** **********************/ #include "udf.h" DEFINE_PROFILE(Temp_Profile, thread, position) { face_t f; real x[ND_ND]; /* this will hold the position vector */ real y; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[0]; F_PROFILE(f, thread, position) = (-1e-26*y*y*y*y*y*y)+(3e-21*y*y*y*y*y)-(3e-16*y*y*y*y)+(1e-11*y*y*y)-(2e-7*y*y)+((1/1000)*y)+13; /*this formula achieved from "curve fitting" */ } end_f_loop(f,t) } how can I hock the file to the FLUENT (what about the type of this file). I already tried to do this steps to call the attached file (its placed at directory file of the model. capture.JPG. am I doing right? regards, |
April 5, 2013, 09:54 |
#19 |
Josy
Rep Power: 17 |
ahvz,
Thank you for clarifying the question. From what I understand, you want to impose this at the walls. Right? Compile the UDF. Then go to Boundary Conditions - 'Wall' - 'Convection' and choose 'User-Defined' not 'New Input Parameter' from the drop down list. Let me know if it helps. Further, please refer the FLUENT manual for help on hooking the UDF's. Good day. |
April 9, 2013, 15:16 |
#20 |
Moha
we are in the same page you right!
its work now! thank you very much |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Creating new user defined material | Vidya | FLUENT | 4 | August 26, 2013 09:26 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
How to use User defined database to add material | sangeeta | FLUENT | 1 | February 25, 2009 13:02 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
