How to Reduce Wall Y-Plus
Old   July 23, 2006, 09:13
Default How to Reduce Wall Y-Plus
rams
Freinds I have solved a combustion problem using non premixed combustion model in Fluent. Am getting every thing correct but, getting a high value of wall y-plus,...
can any one tell me how to reduce wall Y-Plus,...
waiting for u'r reply,...
regards,.....
rams
Old   July 24, 2006, 01:56
Default Re: How to Reduce Wall Y-Plus
Marina
Go to Adapt - Yplus/Ystar panel... Turn on Refine option, select wall zones yoe wih to refine, set the min and max allowed values of Yplus, and click Adapt ...
Old   July 25, 2006, 03:27
Ralf Schmidt
Hi!
The adapt option is ok, BUT: most of the time, it can only dubble or half the y+ values, because the position of the nodes can not be changed with that option. So changing of yplus means to add or remove a node, and the addition can only happend in the middle of a cell.
One hint: Use the smooth/swap option after adapting yplus, do some iterations until convergens, than do the yplus adaption again.
Much better is it, to build a grid with the right yplus from the beginning. Use sizing function and/or Boundary layer option in gambit.
To estimate yplus, have a look at: http://www.cfd-online.com/Forum/main...cgi?read=44320
Ralf
Old   July 25, 2006, 03:36
Albert Franco
I would build a grid imposing the yplus that I wanted, and then recalculating the cell size. As I know you need to estimate velocity of the adjacent flow, carachterist length of the problem, Cf and Ue.
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 05:56
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Wall functions? Pr Main CFD Forum 7 April 8, 2004 06:15
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
