Why does Fluent quit on me?
Old   August 8, 2006, 14:21
Default Why does Fluent quit on me?
Vidya
I'm trying to run my steady state case in Fluent. It workes on another machine that I was using. Now, I re- read the case and data files into another machine in order to hook the UDF and run the unsteady state simulation.
I set up the case and it statrted working fine. However, I minimized the Fluent window in order to do something else and then Fluent just quit (vanushed completely) from the scree. I tried multiple times and the same thing kept happening. Can anyone tell me what's wrong and what I should do? I stopped working on the previous machine due to other problems.
Thanks, Vidya
Old   August 19, 2006, 08:43
Default Re: Why does Fluent quit on me?
kenischi
wrong or opengl-driver not installed
check in prompt
fluent 2d (or 3d) -driver msw
msw forces fluent to use the native windows driver
if gone, install a new driver
you can also set this as service
Vaiable: HOOPS_PICTURE Value: msw/win
kenischi
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
