August 8, 2006, 04:20 |
about vof method
hi how to initialize the volume fraction of secondary phase in volume of fluid method?
August 8, 2006, 08:52 |
Re: about vof method
You can just initialize one phase and then patch the other(s).
solve/initialize/patch |
August 10, 2006, 01:24 |
ok thanks, can we declare boundary conditions on both sides i.e inlet and outlet as one single phase and in between as mixture of both( two phases). if yes , how?
August 10, 2006, 01:35 |
When you set the bc then you have to set it for
- the mixture (values for both phases) - 1īst phase (values just for 1īst phase) - 2īnd phase (values just for 2īnd phase) You can switch between the panels with the bar on the bottom of the bc - window ( default window -> mixture ) hope that helps |
a problem of incompressible two phases(water and gas) with VOF Method | zhangweisnoopy | Main CFD Forum | 9 | August 12, 2011 08:25 |
How to apply VOF method? | yeeking86 | CFX | 7 | August 23, 2010 18:24 |
slop in Hirt's VOF method | GCM | Main CFD Forum | 0 | July 28, 2009 15:44 |
VOF method on inter-tank transfer | Louis | FLUENT | 0 | March 14, 2006 09:28 |
Explain VOF Reconstruction Method | Zi-Wei Chiou | Main CFD Forum | 1 | September 20, 2001 10:26 |
