August 30, 2006, 06:08 |
temperature
one more quastion
I have a problems with temperature of fluid. I have a container filled in half with water and above a water is h2o vapour. I have 3 udf`s. Mass transfer: from vapor to liquid and from liquid to vapor defined by Define_mass_transfer (hooked in phase interactions panel) and heat transfer defined in Define_source makro hooked in BC panel. Without mass transfer (but with heat transfer) everything is ok but when I turn on mass transfer a temperature above a fluid decrease during few iterations (time = 0,001s) to 1,0 deg K (from 333 deg K to 1K). Do you happen to know why? BC are 3 walls (one of them is with temperature 500 K and the rest are heat flux = 0). Upper wall is BC Outflow. I wonder what is wrong because I use mass transfer for boiling (from logic point of view) so I provide (to vapour volume) a vapour (from boiling process) with temperature much higher that one above the liquid . I know that temperature in Fluent is limited to 1 and 5000 K. So 1K (like in my case) is lower limit. What to do?? My mass transfer udf is: if(from_fhase == iliq) { Thread *gas=THREAD_SUB_THREAD(thread, to_phase); Thread *liq=THREAD_SUB_THREAD(thread, od_phase); if (C_T(cell, liq) >= T_SAT) { m_lg = (12 * (fabs(C_T(cell,liq)-T_SAT)))/2000; } if (C_T(cell, gas) < T_SAT) { m_lg = - (12* (fabs(C_T(cell,gas)-T_SAT)))/2000; } } Any clues?? |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 06:36 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
