UDF t o simulate Ionic transfer
Old   August 30, 2006, 17:13
Default UDF t o simulate Ionic transfer
Priya
Hi guys, I am working on fuel cells and would like to simulate the Ionic transfer through the electrolyte, from the anode to the cathode. Any ideas as to how I can do that, what functions can be used. The question is pretty vague as I am mself at the initial stages. So any suggestions are welcome.
Thank you
Old   August 31, 2006, 02:24
Default Re: UDF to simulate Ionic transfer
RoM
Fluent 6.2.16 has a (addon) fuel cell module. It requires an extra license but you can start with the reference guide (fl62fuelcells.pdf).
Good luck, RoM
can VOF simulate 3 phase fluid?should i use UDF?? sincity FLUENT 0 July 18, 2011 07:53
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari FLUENT 0 August 19, 2010 03:01
UDF for Heat transfer coefficient Dong Wenchao FLUENT 2 August 23, 2006 06:35
How to simulate mass transfer in heat exchanger? Yang Bin FLUENT 0 January 17, 2005 06:35
How to simulate heat and mass transfer for drying olivia FLUENT 1 June 20, 2001 13:04
