Help with UDF
Old   September 11, 2006, 12:45
Default Help with UDF
Blas
Hi, can anybody help me out with this simple UDF. It compiles and loads fine but I keep getting the ACCESS VIOLATION error when iteration starts.
The UDF is as follows:
#include "udf.h" DEFINE_ADJUST(temp_cell, d) {
Thread *t;
cell_t c;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,0) = C_T(c,t);
printf("temp pared [C] = %f\n", C_UDMI(c,t,0));
end_c_loop(c,t)
Thanks
Old   September 11, 2006, 14:19
Default Re: Help with UDF
MarkRussell
Did you remember to set the the user defined memory?
Mark
Old   September 11, 2006, 15:49
Blas
Mark, thanks for your help. I have now set the memory locations to 100 (I don't know whether this is too many locations or not)and apparently is the UDF is working (at least the access violation is gone) The thing is this UDF should print the cells' temperatures to the console window but nothing happens. Any idea of what may be going on?
Old   September 12, 2006, 02:54
MarkRussell
Blas,
1. in your code you have
C_UDMI ...
this is the User Defined Memory, and since you only have one (referred to by the last entry in the array of C_UDMI, i.e. 0), recall C and C++ arrays start at zero, set the number to 1, not 100.
2. Try 'Message' instead of printf.
This should work
i.e. Message("hello world");
Mark
Old   September 14, 2006, 07:50
Blas
Hi Mark I have been out for a couple of days. Today I came back and used Message instead of printf and the UDF worked fine!!. Thanks a lot again. Regards Blas
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
