UDF help
Old   September 28, 2006, 07:18
Default UDF help
Matt
Hi all: I am modelling a fire and I have a volumetric heat source inreasing linerly with time upto 15th minute where released heat rate is 5 MW. I have never written a PDF before and i am a beginner in C. So your advices would be appreciated. -Matt
Old   September 28, 2006, 12:55
Default Re: UDF help
Seeker Phil
As most other users will tell you, you got to read the manual.
Use the UDF that defines a profile. You can put a check for the flow time and when the logic is true it will stop increasing the temperature.
Old   September 28, 2006, 15:32
cg
or you could use...
#include "udf.h"
DEFINE_SOURCE(energy_source,c,t,dS,eqn) {
real time = CURRENT_TIME;
real source = 100. * time; /* units of Watts/m3 */
dS[eqn] = 0.;
return source; }
Old   September 29, 2006, 00:10
Matt
thank you much Phil and cg, appreciated..
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
