warning given by fluent when read mesh file
Old   October 1, 2006, 21:56
Default warning given by fluent when read mesh file
major
hello,every one:
when fluent readed the mesh file, the following warnnings were given:
Warning: Number of nodes read (1221300) does not match number referenced (1216320). Resetting counter to match the number referenced. Skipping zone ranshaoqi-inter1-l (not referenced by grid).
I don't know what's the problem. Please give me some advice if you know. Thanks!
Old   October 1, 2006, 22:27
Default Re: warning given by fluent when read mesh file
Hugh
From your error description, it seems that your interial or interface bounday setting error. You can run gambit again to check your mesh is correct!
Old   October 2, 2006, 04:58
sam
this error is due to some unwanted face mesh there. so delelte the face mesh with all and uncheck the lower topology and then again mesh the damain of interst
2ndly it may be due to duplicate faces. so delete face with turn on all
hope it helps u.
p.s Major u still in china?
Old   October 2, 2006, 21:34
major
thanks! I remeshed all the volumes and the mesh file can be readed by fluent successfully. Mr. Sam:yeah, I'm still in China. Do you know about me?
Old   October 3, 2006, 06:32
sam
yeah i know u. my email is sijalahmed@hotmail.com remember it?
Old   October 7, 2006, 09:38
major
of course, I remember you. How are you now? I have sent you an email on Tue., 3 Oct. Have you accepted it? Connect with me pls.
[swak4Foam] groovyBC - compile error? rieuk OpenFOAM Community Contributions 7 June 15, 2011 11:06
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
