regarding fluent help
Old   October 5, 2006, 01:32
Default regarding fluent help
Sunil Kumar
some time during running fluent i m getting error named
Error: divergence detected in AMG solver: x-momentum Error Object: ()
can u tell me why it is coming or how to rectify it.
Old   October 5, 2006, 07:38
Default Re: regarding fluent help
Jason
Based on what you provided? No...
Search the forum. You'll see divergence has many causes. 95% of the time it's your setup or your mesh. 5% of the time you have to do something special during the solution process (like ramp up from a slower velocity).
Search the forum and try the solutions you find there. If you still can't find an answer then post more info on your problem.
Best of luck. Jason
Old   October 5, 2006, 07:58
Default Divergence pointers
kp
In my experience divergence is caused due to several issues such as grid, and unphysical initialization of the problem in hand. With limited information I will try to possibly give you the information of how I eliminate divergence in most of the cases:
For instance have your URFS tightened that helps sometimes, If you are using UDFs make sure you have allocated all the UDMI properly otherwise you can land up with segmentation violation, Specification of gravity should be paid exteme caution, Add models one by one to your case set up for instance if you are using E-E model then add interphase forces one by one, Check your boundary conditions: Many a times boundary conditons are a major contributor to divergence, if you are performing unsteady calcualtions then try with smaller step size for the first few iterations then switch to coarser time steps, use MUSCL scheme sometime it helps. I gahter this might be helpful.KP
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
