How to display stream function in 3D simulation?
Old   October 15, 2006, 21:58
Default How to display stream function in 3D simulation?
Jass
Hi, i'm Jass. Now i'm working on Underground Car park simulation. I would like to know How to display stream function in some surface of 3D simulation?
Thak you for your advance help
Old   October 16, 2006, 08:19
Default Re: How to display stream function in 3D simulatio
Jason
Stream function is calculated for a 2D flowfield, and isn't available in 3D. You can plot pathlines in 3D, but these won't be fixed to a plane (look into the oil-flow option in the pathlines... I know this fixes streamlines to a wall, but you may be able to fix them to any plane). You can plot Vectors on a plane and you can turn off the out-of-plane component (Display->Vectors then Click the Vector Options button to see more options).
Hope this helps, and good luck, Jason
Old   October 17, 2006, 13:08
Jass
Thank you so much
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 08:53
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Stream function in Star-CD DenizeN Siemens 0 September 20, 2006 03:48
