How to model suction flow in an airfoil in Fluent
Old   October 17, 2006, 20:37
Default How to model suction flow in an airfoil in Fluent
Davy
I'm an undergrad in aerospace engineering , researching for a project of mine. I am having problem finding information online as to how to model an airfoil (wing)with tiny holes in part of the wing in Gambit.
Moreover, I am uncertain if fluent is capable of modeling a suction flow through this hole at supersonice air flow, I was told by my instructor to research online to see if anyone has done anything similar but have no sucess in doing so.
In addition to that, i was questioned by my instructor whether or not if the flow can magically disapper after they are 'sucked' in to the airfoil..(in real life situation, the flow being sucked in through the wing can be sent to a propulsion and exit through the exhaust, but programming all this in Fluent would almost be impossible for me)
It would be highly appreciated if any one of the bright minds here can help me out with this. Thank you
Old   October 18, 2006, 01:57
Default Re: How to model suction flow in an airfoil in Flu
Ryan
Yes it is possible.
The flow will dissappear once it reaches this boundary.
Iam not sure if you have details of the pressure in this boundary or it will be wise to set the pressure as zero and check what it is doin?.
Good Luck!!
Regards
Ryan
Old   October 18, 2006, 18:49
Davy
Thanks Ryan, I talked to another professor of mine today He suggested that it will be better for me to 'program' the location of those suction holes as 'outflow' boundary with a mass flow going into those 'holes'
I just need to know if this is 100% do-able for a beginner in fluent in a 3 to 4 months span.
Old   October 19, 2006, 08:31
Jason
Do you actually know the mass flow through each of the holes, or do you know the suction pressure being applied?
Be very careful about "outflow" here... the outflow BC in Fluent has some major assumptions built into it and I would not recommend using it in your circumstance. Check chapter 7.10 in the Users guide for assumptions in the outflow BC (if you don't have access, do a google search... there's a couple universities that have it available online).
I recommend the pressure outlet for these holes. If you know the actual mass flow through each hole, you can set the target mass flow rate (if you define all the holes as a single BC, I believe the target mass flow rate is the total of all of the faces so that you can have some faces pulling more air and some pulling less).
Good luck, Jason
Old   October 23, 2006, 03:56
Vincent
I think it is only possible to simulate a relatively large "gap" in the wing. If you want to simulate something like boundary layer suction, Fluent is not able to do the job.
I'm working on BLS; Fluent cannot calculate the influence of a small suction velocity on the boundary layer profile. Fluent takes the velocity normal to a wall equal to zero by definition, therefore suction through a wall is not possible. If you use a different BC, such as velocity/pressure outlet, Fluent will not calculate a boundary layer at all.
Coupled Flow model RalphS OpenFOAM 1 November 15, 2010 03:51
Baldwin-Lomax model in wall jet flow K.S.Chang Main CFD Forum 0 December 7, 2005 01:51
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
How Fluent treat the pressure term in imcompressible flow Ray FLUENT 1 May 24, 2000 16:50
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
