October 16, 2006, 09:58 |
EULER PARTICULATE DEPOSITION
I'm trying to simulate how particulate and PM10 can settle in a urban canyon. I don't how verify if deposition occurs in my eulerian multiphase model. Is there a procedure to read the mass rate toward the walls? I'm using fluent 6.1.22 with k-e turbulence model and mixture multiphase model. Thank you in advance to everybody want help me
Mirko |
October 18, 2006, 05:52 |
Re: EULER PARTICULATE DEPOSITION
Hi Mirko,
you have an interesting problem. I can't answer your question right away, but maybe you could describe your problem more in detail to me. Do you have a paper puplished where i could read through? If possible you could try Descrete element method, because you can track your particles and therefore, estimate there deposition. Much luck Best regards Stefan |
Particle deposition on circular cylinder in turbulent flow | Julian K. | CFX | 1 | October 3, 2011 17:51 |
euler euler multiphase modelling | mdsvjpk | FLUENT | 0 | July 23, 2011 11:11 |
euler euler multiphase modelling | mdsvjpk | FLUENT | 0 | June 14, 2011 11:50 |
Blood Flow - Euler Euler | Ilias | FLUENT | 0 | January 12, 2009 10:16 |
euler model | CN | FLUENT | 0 | July 4, 2005 16:35 |
