Pls help on this
Old   October 20, 2006, 14:43
Default Pls help on this
OEUGA
I was bothered by a simple problem. 2-D tubes with all four sides are walls. The problem is when I try to initialize the pressure field. It display 0 atm no matter how high I give the intial pressure. The setting I looks quite fine and the geometry is very simple. Why this will happen?
Thank in advance
Old   October 20, 2006, 16:02
Default Re: Pls help on this
Robin
So you have no inlets or outlets, just 4 walls and 2 symmetry planes?
What fluid properties are you using? If it is not compressible, the solver will set the first control volume equal to your domain pressure. This would give you a zero relative pressure everywhere.
Try using a compressible fluid (Air Ideal Gas for instance).
Regards, Robin
Old   October 20, 2006, 16:04
Robin
Sorry, didn't realize I was looking at the Fluent forum. The same probably applies, however (except for the symmetry planes).
-Robin
Old   October 21, 2006, 15:55
OEUGA
Robin, Thank you anyway.
HELP PLS: Simplefoam manipulated to add diffusive mass transport...but solver stops!! 1gn0rant OpenFOAM Running, Solving & CFD 1 August 13, 2010 11:02
help me understand porous media in fluent~ pls pls.. :( naftalena FLUENT 0 February 28, 2010 12:20
i need help following problem pls pls help gmani CFX 4 March 31, 2009 09:39
Turbulence model for subsea stability, Pls. Abiodun FLUENT 1 August 23, 2007 06:52
multi phase flows....pls help... karthik FLUENT 0 November 16, 2005 09:15
