Compressible and Imcompressible ?
Old   October 23, 2006, 22:41
Default Compressible and Imcompressible ?
Pathway
I simulate two cases. One is using air as fluid through a small volume, and the other is using water-liquid as fluid through a small volume.
I only konw the mass flow rate, so I set inlet as mass flow inlet and outlet as pressure outlet.
Do the two cases set correct?
In fluent, it says using mass flow inlet for compressible flow.
And what's the meaning of mass imbalance?
Thanks a lot.
SIMPLE algorithm for compressible flow and Main CFD Forum 6 August 10, 2015 14:06
Can a compressible solver solve incompressible ? jinwon park Main CFD Forum 17 December 13, 2007 05:00
how to define compressible or imcompressible tian FLUENT 1 May 16, 2003 04:42
CFD method for High Re flow Toshiyuki Arima Main CFD Forum 3 May 29, 2001 11:18
What's the influence of SIMPLE to compressible flo Jing Main CFD Forum 8 May 16, 2001 12:13
