October 29, 2006, 11:11 |
compiled UDF
when i compile a UDF as interpreted UDF,it works.but when i compile it as compiled UDF it shows error.
1 file(s) copied. (system "move user_nt.udf libudf\ntx86\2ddp")0 (system "copy C:\Fluent.Inc\fluent6.1\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2ddp")() Done. Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. Error Object: () Looking for help. Thanks. |
November 8, 2006, 19:05 |
Re: compiled UDF
Hi, I met the same problem. Can anybody give some solution or comments on this problem...
Thanks! |
November 15, 2006, 13:04 |
Re: compiled UDF
Your compled lib ( default is libudf) should be in the same directory where your cas file. Good luck Miri
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
I want to use pressure of 1 face in udf that compiled on other face | iman_1844 | Fluent UDF and Scheme Programming | 3 | June 10, 2010 12:55 |
Why udf can not be compiled in my pc? | Xinqiang | FLUENT | 0 | June 10, 2009 14:32 |
difference between udf compiled and udf interprete | chandra sekhar | FLUENT | 2 | April 11, 2006 00:04 |
how to quit compiled or interprited UDF | tian | FLUENT | 0 | April 8, 2003 23:53 |
