[Sponsors] | |||||
Hi!
I have a problem, when starting my simulation (3d, segg solver, k-w, 4 sym-planes) following error appears: Error: cx-xy-plot-data: invalid number Error Object: nan I have a residuals monitor and a velocity surface monitor at the outlet of the domain. What is the problem? Ralf |
if you write your surface monitor in a file, check that the path is ok
Hi!
I solved the problem: I accidentally defined the outlet of the volume as mass flow inlet. So I hade two inlets and no outlet (the other faces are wall or symmetry BC). It works fine now!! Ralf |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Simulation doesnt start iterating | saisrikar | STAR-CCM+ | 3 | August 15, 2011 00:14 |
| Monitor pressure difference while iterating | Michel | FLUENT | 0 | December 9, 2008 09:26 |
| UDF:Is there a MICRO to stop iterating | andy P. | FLUENT | 2 | February 9, 2007 20:49 |
| error when iterating - no residuals, no results | Ralf Schmidt | FLUENT | 2 | December 1, 2006 11:29 |
| fluent error while iterating | Ralf Schmidt | FLUENT | 9 | July 21, 2006 09:17 |
