compiled UDF
Old   October 29, 2006, 11:11
Default compiled UDF
bharti
when i compile a UDF as interpreted UDF,it works.but when i compile it as compiled UDF it shows error.
1 file(s) copied. (system "move user_nt.udf libudf\ntx86\2ddp")0 (system "copy C:\Fluent.Inc\fluent6.1\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2ddp")()
Done.
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Looking for help. Thanks.
Old   November 8, 2006, 19:05
Default Re: compiled UDF
Varma
Hi, I met the same problem. Can anybody give some solution or comments on this problem...
Thanks!
Old   November 15, 2006, 13:04
Miri
Your compled lib ( default is libudf) should be in the same directory where your cas file. Good luck Miri
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
I want to use pressure of 1 face in udf that compiled on other face iman_1844 Fluent UDF and Scheme Programming 3 June 10, 2010 12:55
Why udf can not be compiled in my pc? Xinqiang FLUENT 0 June 10, 2009 14:32
difference between udf compiled and udf interprete chandra sekhar FLUENT 2 April 11, 2006 00:04
how to quit compiled or interprited UDF tian FLUENT 0 April 8, 2003 23:53
