November 26, 2006, 08:43 |
Vaiable Material properties
Hai friends,
Can any one explain how to give variable material properties. Actuall i had a block consist of two different materials. How to give material properties seperatly. Any help please |
November 26, 2006, 11:57 |
Re: Vaiable Material properties
Create two different volume for each block and assign properties. This would be the easiest way.
November 29, 2006, 13:12 |
Hi Pialisen,
I think when you set material, you set from menu Define/Material... This is a menu for load material from library. If you have 2 materials or more, use menu Define/Boudanry Condition.... then select 'Fluid.1' and click 'Set'. Then, the dialog box will shown you a material that you want to choose for 'Fluid.1', And, I think you should have 2 fluids ,( set by Gambit ) Mr.Nantaratn |
problem with specifying material properties | cavani | CFX | 5 | March 9, 2011 18:36 |
Temperature-dependent material properties in chtMultiRegionFoam-Solver | sebonator | OpenFOAM | 0 | November 15, 2010 08:15 |
How to add more material properties | sarahsun | CFX | 1 | October 27, 2009 07:27 |
