error when iterating - no residuals, no results
Old   December 1, 2006, 09:23
Default error when iterating - no residuals, no results
Ralf Schmidt
Hi!
I have a strange error:
when I start iterating my file, following message appears:
Error: cx-xy-plot-data: invalid number
Error Object: nan
When I try to display results:
Error: cx-set-real-entry: wta[2](float)
Error Object: nan
What is the problem??? The BC are quite simple (mass flow inlet), the grid check is ok. There is no udf or something like that.. The file has about 1.500.000 cells - I hade simulations running with a similar number of cells. I can display the grid.
Any Idea???
Old   December 1, 2006, 09:26
Default Re: error when iterating - no residuals, no result
Ralf Schmidt
I forgott the strange thing:
after I start iterating, Fluent gives the message given, but it seems to iterate!! It plots the "normal" message for this king of geometry:
reversed flow in 1740 faces on pressure-outlet 156.
Old   December 1, 2006, 11:29
Default problem solved!
Ralf Schmidt
Hi!
I solved the problem: it seems to be, that there are two faces on the same place (but other than normal, Fluent doesn't told me when reading the grid). Another reason could be, that an outer bondary face was defined as internal.
Now, simulation is running very fine...
Thanks for reading
Ralf
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
Mesh size and solver residuals... Scott CFX 5 December 15, 2008 17:10
Problems with repeating results Lee Siemens 4 May 26, 2006 03:39
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
benchmark results stefan Siemens 3 September 10, 2001 09:48
