About GAMBIT import
Old   December 22, 2006, 14:28
Default About GAMBIT import
Spyros Stamatelos
Hey guys and gals, I want to obtain a surface geometry in GAMBIT for which I have two files: one that contains the vertices (.vrt) and one that contains the triangles that comprise the surface (.bnd). Do you know how I should combine them in order to reproduce the geometry in GAMBIT?
Thanks a lot, Spyros
Old   December 28, 2006, 07:12
Default Re: About GAMBIT import
Jim Clancy
Spyros, From my expeience specially with complex geometries, If you have the drawings I suggest you to create the geomtry withing Gambit rather than importing from other CAD systems. In many cases you will endup with cleaning up process and tolerance problems. Good Luck Jim
Gambit Import error GUEST FLUENT 7 May 30, 2019 11:46
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 14:21
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
How to Import 3D objects from Pro-Engineer to Gambit? Tomb FLUENT 3 July 5, 2000 12:12
Autocad import into Gambit Paul Main CFD Forum 5 July 12, 1999 04:19
