January 10, 2007, 14:49 |
Passive Scalar
Folks, I have a combustion problem with multiple gas injectors. The analysis looks good so far but a question has come up. Can I show how much of the unburnt fuel at a given point has come from each injector.
I believe that the way to do this is to use the UDS (user defined scalar) and have set those up and the results seem broadly plausible. But.... I seem to be getting small but finite concentrations of all my passive scalars well upstream of the injection points in the oxidizer air stream. The flow is super sonic at around Mach 2 so certainly these scalars cant be convecting upstream. Am I just seeing a start up transient to the solution (I am running this SS)? Or am I missing something in my setup? I have used the default values for UDS diffusivity relative to my "real" scalars. That value defaults to 1. I am assuming that if I get this set up correctly a finite concentration of a passive scalar will indicate that any unburt fuel in a cell can be traced back to one or more injection locations based on the relative concentrations of the N UDScalars I have defined. Ultimately I would like to track product production as well but I think I would have to add N more UDScalars and a UDF to destroy the correct amount of fuel tracking scalar and create the correct amount of product tracking scalar. Any thoughts? Thanks - Andy |
dieselFoam problem!! trying to introduce a new heat transfer model | vivek070176 | OpenFOAM Programming & Development | 10 | December 23, 2014 23:48 |
passive scalar for carbon monoxide | kraizy | STAR-CCM+ | 0 | October 12, 2009 20:13 |
Need help: Can I use passive scalar in Fluent? | Susan YU | FLUENT | 0 | June 26, 2009 04:56 |
solving passive scalar by user function in AVLFIRE | huyp | Main CFD Forum | 0 | September 4, 2008 10:21 |
Can I specify a passive scalar flux source in ccm+ | eric | Siemens | 0 | June 11, 2008 14:48 |
