STL file import to GAMBIT
Old   December 18, 2006, 16:00
Default STL file import to GAMBIT
Spyros Stamatelos
Hey guys, I am trying to import an STL format geometry file in GAMBIT but it produces an error: 'Error encountered while reading the header information'. I have also tried to convert the file via the fe2ram command but it did not work either. Moreover does anyone know how to transform a STAR-CD format file (.cel) in FLUENT format?
Thanks a lot for your help I appreciate it
Spyros
Old   December 19, 2006, 04:56
Default Re: STL file import to GAMBIT
Michael B
If you have problems with STL or other formats, try to read it into a CAD package to see what's wrong.
Old   December 25, 2006, 07:45
Darthvader
The file header is probably corrupt. Check the file again
Old   January 11, 2007, 12:20
Kevin Shanley
Hello.
I am getting the same error.
The header doesn't appear corrupted; what should it look like?
Thanks, Kevin
how can i import igs file in gambit? Javier FLUENT 2 May 23, 2011 10:51
import STL file in Gambit calvin123 FLUENT 13 December 1, 2010 18:55
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
import *cas file from fluent to gambit?? Rashmi FLUENT 5 October 25, 2005 01:18
