Tee Channel (Mixture and Eulerian Multiphase Mode) |
January 23, 2007, 02:22 |
In tutorial 18 of Fluent 6.2 (Using the Mixture and Eulerian Multiphase Model).
If I change one velocity-inlet is only water in, and the other is only air in. Then they meet in the channel. Can I use the same model as the tutorial? Or it has another method to use! Thank you, sincerely. |
mesh size in Eulerian multiphase flow - liquid/solid mixture | microfin | FLUENT | 4 | December 23, 2016 13:55 |
Difference between Mixture & Eulerian multiphase ? | Shankar | FLUENT | 6 | October 7, 2015 08:45 |
Mixture model for Multiphase flows | sandisk | FLUENT | 0 | January 23, 2011 18:05 |
Mixture and Eulerian Model | Hassid S. | FLUENT | 1 | August 9, 2007 07:24 |
mixture or eulerian | van | FLUENT | 1 | March 20, 2006 04:55 |
