UDF
Old   January 23, 2007, 08:08
Default UDF
pirat
does anyone know if the function Lookup_Thread works if the id passed as the second input is not a boundary id but a surface id? Thanks
Old   January 23, 2007, 11:45
Default Re: UDF
Sujith
No for this macro, the id should be a face thread or cell thread. Postprocessing surfaces cannot accessed using this macro.
Old   January 24, 2007, 04:49
Default Re: UDF
pirat
Is there any macro that accesses the postprocessing surfaces? I don't think so, but it will be really useful to my work.
Old   January 24, 2007, 07:45
Default Re: UDF
Akshay
I am not sure what you wish to do? You can create a edge/face in Gambit and name it as interior. Lookup thread can be used on it.
Old   January 24, 2007, 08:10
Default Re: UDF
pirat
yes i know, the fact is that i have to put something like 30 sphere surfaces and meshing all the volumes in gambit is a great lost of time. If exists a function that returns a pointer to the faces of a postprocessing surface I'll be able to export without changing the mesh.
Old   January 24, 2007, 10:42
Default Re: UDF
Sujith
With out UDF you can export the values on the post processing surfaces using exporting the reqd data as ASCII
file - export - ascii
Old   January 24, 2007, 11:22
Default Re: UDF
pirat
thanks guys I solved the problem, anyway I guess exporting in ascii is the only way.. not the fastest
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
