Gnuplot and Fluent on Windows
Old   January 19, 2007, 09:43
Default Gnuplot and Fluent on Windows
Arianna
Hi!!!
Could you tell me if it's possible to run gnuplot on Windows???...and in which ways it can work with FLUENT???
Sorry for my ignorance!!!
Arianna
Old   January 19, 2007, 13:47
Default Re: Gnuplot and Fluent on Windows
CE
Yes, there are version of gnuplot that has been precompiled for 32-bit Windows. You can obtain them from here: http://sourceforge.net/project/showf...ackage_id=1996
As to how you can get it work with Fluent, that may require a bit of programming in gnuplot script. To visualize the result from Fluent, you would have to export the data from Fluent in ASCII format. A proper Gnuplot script file should be able to read the data and present it.
Good luck!
Old   January 19, 2007, 14:31
Charles
Gnuplot is a handy way of monitoring convergence without running the Fluent GUI, something which is really useful when running on a remote machine.
Old   January 23, 2007, 07:37
Arianna
Thank you very much for your answers!!!
Could you give me any other tips on gnuplot???
Arianna
Old   January 25, 2007, 11:00
Default GNUPLOT: more specific question
Arianna
Hi!!!
I succeedeed in plotting data file in GNUPLOT, now I'd like to know if it's possible to pass data file to GNUPLOT in an automatic way (e.g: at every iteration). Thank you in advance!!!
Arianna
