Error while saving the case and data file
Like Tree1Likes
  • 1 Post By beer
Old   January 25, 2007, 12:07
Default Error while saving the case and data file
Sri
I am running a case in which i enabled Autosave for every timestep. After few timesteps,it's giving the error " Error: write_thread_svar!" while writing the case and data file and terminating.
Can someone help me on this?the reason why i am seeing this error?
Thanks
Old   July 23, 2012, 20:54
Negin Nazarian
nenazarian is on a distinguished road
Hi
Do you remember how did u fixed this problem?
nenazarian is offline   Reply With Quote
Old   July 24, 2012, 02:41
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi nenazarian,
can you tell me what you wrote in the command line?
Usually I use a similar command:
root/folder/subfolder/example1/example1
(not example1.cas, I haven't tried yet but I think that it doesn't work with the format extension ...)
Bionico is offline   Reply With Quote
Old   January 8, 2013, 11:34
beer is on a distinguished road
I'm sure you have already solved it, but just in case of...:
I just had the same problem a few minutes ago. In my case it was trivial, the hard disc had no free space.
Greetings
samity12 likes this.
beer is offline   Reply With Quote
Old   September 2, 2015, 06:24
Default Error: write_thread_svar!
Akshay
akshay23p is on a distinguished road
Originally Posted by Sri
;138559
Thanks
What is the solution to this problem?
akshay23p is offline   Reply With Quote
Old   September 2, 2015, 08:43
pakk will become famous soon enough
If the root problem is that your harddisk is full: delete files, or buy a bigger harddisk.
pakk is offline   Reply With Quote
Old   September 2, 2015, 09:55
Akshay
My harddisk is 70 % free.
Error in Saving either or both case and data files Fascal FLUENT 4 July 18, 2010 11:12
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 16:31
Initial condition data file from coarse mesh case Kushagra FLUENT 1 July 25, 2008 21:53
Saving particle (DPM) data to file? Philip FLUENT 2 June 12, 2006 01:41
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
