Running on Distibuted Memory linux itanium cluster
Old   January 29, 2007, 00:18
Default Running on Distibuted Memory linux itanium cluster
Josh
I have been trying to run Fluent on a cluster consisting of 4 hp 64 bit hp itaniums. Each has passwordless ssh between each other node. Each once can launch Fluent and the command ssh node1 fluent works as well. From what i could tell I should run using the command "fluent -t2 -pethernet -mpi=mpich1-ssh -cnf= hostfile.hosts". This gives the following error message "-mpi option "mpich2-ssh" not supported with this hardware/interconnect". Is this not supported on itaniums? Is rsh access required for itaniums?
running out of memory in Gambit, Help!!! ahmet FLUENT 19 October 5, 2013 06:01
Who is running Phoenics with a cluster? Maria Morabito Phoenics 2 January 4, 2004 05:07
linux cluster Johan Carlsson Main CFD Forum 2 June 21, 2003 07:14
To Jonas: Linux Cluster Mark Render Main CFD Forum 1 June 20, 2002 04:19
Linux Cluster Computing Mark Rist Main CFD Forum 5 September 10, 2000 05:51
