Fluent variables
Old   February 12, 2007, 13:56
Default Fluent variables
HSeldon
Hi all, I need to get the values of the lift and grad coeff in order to complete an UDF. What are the name for those variables to include them in my UDF??
Thanks in advance.
Old   February 12, 2007, 22:31
Default Re: Fluent variables
Rizwan
Can u please be a bit more elobarate? As far as I can guess, if u need to calculate drag force, then u need to find pressure distrution on the surface or region and multiply it with area vector.
force = 0.0 begin_f_loop (f, t)
F_AREA (A, f, t);
force = force + F_P (f, t) * NV_MAG (A);
} end_f_loop (f, t)
Old   February 13, 2007, 10:04
HSeldon
Sorry for been so "short" in my explanation. Yes, basically I need what you put. Because I need to write into a file the Cd and/or Cl value to a txt. I know that fluent can do it, but this excersise is for college in order to practice C language and UDF stuff.
Regarding the code you put above: What F_P does? (pressure?)
Thank you for the input Rizwan!!
Old   February 13, 2007, 12:44
Rizwan
F_P is the built in macro that will find pressure on the face and is available from solver whenevr it is called from the udf.
Regards
Old   February 13, 2007, 13:14
HSeldon
Thank you very much!
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 06:47
Redefining variables in fluent instead using limits (control solution) akhlaghi FLUENT 0 February 19, 2011 06:14
How to modify variables in Fluent solver yizhou FLUENT 1 June 19, 2006 20:00
