Problems detected after running more than 500 iterations |
February 16, 2017, 22:30 |
Jun
Rep Power: 9 |
dear all,
so i have gotten thru most of the problems i faced earlier and now i have tried solving the problem. But it still leaded me to another dead end where i encountered another issue here... anybody has any idea what went wrong? the values of Cd Cl and moment is slowly converging but out of a sudden, divergence detected in the solver, epsilon. here is an image to summarized my topic. any help is appreciated. thanks, JX- |
February 19, 2017, 23:42 |
Lucky
Rep Power: 66 |
It's not all of a sudden really. It took 500 iterations because you lowered the relaxation factors.
As with all convergence problems, check your boundary conditions to make sure you have specified correct ones, make sure you have a good initial guess, and then check your mesh quality. The COUPLED solver is more unstable, I recommend trying the SIMPLE solver (with all default settings) to see if it still blows up. Also try using the higher-order term relaxation option in Fluent, it helps a bit for bad initial guesses. |
February 21, 2017, 01:45 |
#3 | |
Jun
Rep Power: 9 |
this is what i get when i use the SIMPLE solver with all default settings while remaining the other conditions the same as before. i really wonder whats wrong... |
February 21, 2017, 11:31 |
Lucky
Rep Power: 66 |
Looks look typical divergence behavior. Divergence is much easier to detect when you don't tweak anything. =)
Go through your case setup again. Make sure boundary conditions are correct. Make sure you have a good initial guess. Make sure your mesh is okay. Play with your initial guesses for the k and epsilon. Dbl, triple, quadruple check the specification of k and epsilon at boundaries. Usually people do not specify k and epsilon directly but use the turbulence intensity and something. |
settlingFoam unstable? | bendel_boy | OpenFOAM Running, Solving & CFD | 38 | July 8, 2016 05:07 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
