Car aerodynamics simulation (Pls help, urgent)! |
February 22, 2007, 07:19 |
Hello,may i have somebody who had done simulation on car aerodynamics using fluent,Gambitor Tgrid to give me a helping hand? I am doing car aerodynamic simulation for my undergraduate thesis. How to build a boundary layer around the car using Gambit or Tgrid? I had try to do this stuff, but Gambit show "Error:Boundary layer tempBL, cannot be attached to the combination face.xx edge.xx,because it conflicts with an existing mesh on edge.xx:.Before building the boundary layer,do i need to calculate the boundary layer or just roughly assmume a thickness for the layer ? If yes,what is the formula for the calculation? And is it necessary and what is the significant to build this boundary layer for simulation?
Thanks lot!! |
February 23, 2007, 16:06 |
Re: Car aerodynamics simulation (Pls help, urgent)
I'd advise you to build a normal grid completing your y+ requirements. I've done aerodynamic simulations and never used the BL building proposed by Gambit.
Perhaps I'm wrong Good luck |
Simulation of impedance tube (pls help) | khoodav | FLUENT | 0 | February 26, 2011 15:47 |
Urgent! pls Help! | A. H. Jaberi | FLUENT | 1 | November 7, 2004 18:51 |
* urgent help required for simulation of pipe flow | mei | Main CFD Forum | 3 | July 3, 2002 04:22 |
Simulation of Car Cabin Air Flow | Erwin Susanto | Main CFD Forum | 0 | May 19, 2000 11:33 |
car body aerodynamics | Althea | Main CFD Forum | 3 | June 15, 1999 14:09 |
